HKPro5
Cres
2003 Mazda Protege5
Exterior
Engine
Interior
Performance Mods:
Eaton M62 "clutched" supercharger off a Mercedes SLK 230 w/ Custom Charge Piping
SSAFC V2
4-1 Headers (wrapped)
Powder Coated Valve Cover (wrinkel red)
Slim fans and controller
FMIC
6.1" crank pulley (9-10 PSI)
Medieval Motor Mounts
Custom 2.5" Exhuast w/ Civic High Flow Cat
Custom CAI, K&N Filter
Suspension Mods:
Progress Rear Sway Bar
HKPRO5 Endlinks
GT Spec Front STB
GT Spec 4 point trunk Cage
GT Spec Trailing Arms
Tein Super Street coilovers
Exterior Mods:
P5 Fog Deletes
Mazda Rx7 Rims (16x8) 225/50/16 Potenza RE01R
Mazdaspeed6 Rime (18x7) 225/45/18 NEXEN 3000
Autoexe Front Lip
Aspec Sideskirts
3m Carbon Fiber Vinyl Wraped Rear Spoiler
Interior Mods:
Corbeau FX1 PRO
TWM Short Shifter
Proper+ Shift Knob
AEM Wideband
Blitz Dual Turbo Timer
Harness Bar
Custom Door wrap
Stereo Mods:
Custom 12" Stealth Sub Woofer Box
12" MTX Sub Woofer
Pioneer Everything
Awards Won:
MOTM April 2009
Best Protege at local Show
Circuit
Chris Bernardo
2003.5 Protege5
Exterior
Mazdaspeed Front Bumper
Mazdaspeed 03.5 Front lip
JDP Replica Front Spoiler
iSport Wing Lip (molded)
Tint 50% front, 35% rear
WeatherTech Window Visors
JDM Familia Sport20 Taillights
JDM Familia Emblem
VG Shark Fin Antenna
Mazda6 Wagon Rear Wiper
DDM Tuning 6000K 55W HID Kit
PIAA 1500XT Fog Light Housing
DDM Tuning 3000K 35W HID Kit
Laminx Yellow Film (fogs)
CDM Headlight Blackout
Interior
Mazdaspeed Floor Mats
Mazdaspeed Door Sills
Mazdaspeed Pedal Set
Carbon Fiber and Brushed Aluminum vinyl
Monster Knobs Shift Knob
Redline Goods Shift Boot
LED Lighting
Electronics/Stereo
Kenwood DNX8120 with iPod Adapter
Eclipse XA4000 4-channel Amplifier
Eclipse XA1000 Mono Amplifier
Polk Audio SR6500 Components
Polk Audio DXi Midbasses
Monster Cable Wiring
Dynamat & RAAMmat Sound Deadening
Optima Red top battery
Tsunami battery top and fused distribution blocks
Wheels/Tires/Suspension
Blitz Racing Type-01 17x8 +35
Rays Blue Extended Lug Nuts
Yokohama S-Drive 215/40/17
BC Racing BR-Type Coilovers
GT-Spec Trailing Arms
Carbing Front/Rear Strut Tower Bars
Racing Beat Rear Sway Bar
Engine
Mazda MP3 ECU
Mazda MP3 Intake Manifold
Perrin Fuel Rail
Outlaw Engineering thermal spacers
AWR Deep Sump Oil Pan
Intake Snorkel Delete
Mazdaspeed Japan Panel Filter
Racing Beat Catback Exhaust
Corksport Exhaust Hangers
AWR Side Motor Mount Inserts
Corksport Front/Rear Motor Mount Inserts
Medieval Air Diversion Panel
Black Wrinkle Valve Cover
Tein Hood Dampers
Mild Engine Harness Wire Tuck
AWR Header (ceramic coated) - Coming soon
SLS Catted Midpipe - Comming soon
Transmission/Drivetrain
Mazdaspeed 16lb Flywheel
Mazdaspeed LSD (welded)
Exedy Clutch
NSN Motorsports 5th Gear Upgrade
Kartboy Short Shifter & Shifter Bushings
Joka1
Rob McCord
2003 Mazda Protege ES-T
Performance Mods:
-T3/T04 Turbo
-Fully built motor at 8.1 compression- Pauter Rods/ Wiesco Pistons/ Bored .20 over/ ARP Main Bolts/ Clevete Bearings
-Perrin Intercooler
-Turbo XS Rfl Bov
-Tial Wastegate 8 PSI Spring
-Mpi Tuner EMS w/Turbo Module
-NX N-tercooler system
-550 Injectors
-2 Extra 440 Injectors
-Ceramic Coated PG Intake Manifold
-Custom ADJ Cam Gears
-MAM Tubular Manifold Ceramic Coated
-Custom 3" TurboBack Exhaust w/ Magnaflow Muffler
-Greddy Profec B EBC
-Exedy Stage 2 Clutch
-Fidanza Flywheel
-AWR Deep Sunk Baffled Oil Pan
-Greddy Full Auto Turbo Timer
-Custom Turbo Pipes
-Hose Technique Turbo Couplers
-Weapon-R Engine Dampner
-AWR Front/Rear Motor Mount
-JIC A2 Coilovers
Engine Apperance Mods:
-Dg Carbon Fiber Engine Cover
-Polished Valve Cover
-Custom Hood Props
-GT Spec Strut Bar ( Ends Ceramic Coated/ Middle Black)
-Custom Radiator Shroud
-Hose Techniques Blue/Black Vacuum Line Kits
-Custom Painted Turbo Compression Housing
-Blue Top Optima Battery
-Cut Valve Cover to Show Cam Gears
-Blue Radiator Overflow Can
Exterior Mods:
-Full Msp Front End Conversion
-DG Front Lip
-Buddy Club 2 Side Skirts
-Buddy Club 2 Rear Bumper
-VIS C/F Hood Custom Painted
-Vis C/F Trunk Lid
-EVO 8 Spoiler
-DG C/F Grill
-Piaa 540 Foglights
-18" ADR Sokudos Pwdr Coated Black
-Smoked Taillights
-5% Tinted Windows
-JDM Style Headlights
Interior Mods:
-4 Point AutoPower RollCage
-Reapulstered Backseat W/NX bottle Mounted in the Center
-Autometer Phantom Wideband A/F Guage
-Autometer Phantom Boost Guage
-Autometer Phantom Pryometer
-Autometer Phantom Volt Guage
-Autometer Phantom Oil Pressure Gauge
-Autoguage 3 Guage A-Pillar Pod
-Forcefed Modified Steering Wheel Pod
-Forcefed 2 Guage Cluster Surround
-Adj Shiftlight
-Bride Blue/Black Front Seats
-Sfi Certified 3" 5 Point Racing Harnesses
-Reapulstered Door Panels
-Dyed Headliner
-Nokia Blue Shif Knob
-Nokia blue Racing Pedals
-Sparko Black Suede/Leather Steering Wheel
-Blue Led's Under Each Seat
-C/F Covered NX Arming Switched
-DG C/F Doorsills
Stereo Mods:
-Compustar Alarm
-Kenwood Indash 7" Touchscreen
-7.2" Rear TV
-Infinity Kappa Interior Speakers
-Dynatatted Trunk and Interior
-PS2 Mounted in Trunk
CityRacer
Christopher
1993 Ford Probe ~ Base model
2.0 FSDE
OEM long runner intake manifold
OBX turbo manifold
Tial 35mm wastegate w/ 1bar spring
Precision GT30R (.48ar~t / .60ar~c)
custom 2.5" downpipe w/ integrated wastegate dump and a v~band
mild steel exhaust with resonator and strght through oval muffler (looks stock)
custom aluminum 2.25" intake piping
27 x"12"x 3" polished front mount intercooler
Synapse Synchronic recirculated by pass valve
AWR~front~rear~pass side engine mounts.
custom pass side engine mount reinforcement
Weapon/R engine torque damper / mounted trans~front xmember
SS radiator lines
Ron Davis aluminum radiator
oil pump relief spring shimmed 6mm~Oil adapter plate~remote zr1 oil filter~thermostatic 180* bypass valve~12"x9"x1.5" oil cooler~ Accusump 1qt w/ manual valve set at 28psi unload with one way check valves.
eibach valve springs
SS valves
ported head
adjustable cam gears
block bored .20 over
Wiseco 8.7:1 pistons
K1 connecting rods
Clevite bearings
Cometik extra thick head gasket
ARP main/head bolts
EGR/PCV delete
A/C delete
MSP~ p/c valve cover with c/f engine cover
3" GrandNational aluminum turbo inlet pipe
Silver mesh intake filter
Dual oil catch cans~ Jaz / 42DraftDesigns
Unorthodox aluminum underdrive pulley
Medieval aluminum water / power steering pulleys
protege power steering pump conversion
ManiacMotors 110amp alternator w/ 5-rib overdrive pulley
Kinetick HC1800 battery
Jacobs Electronics Accuvolt set at 15v
Zero gauge wiring for battery to trunk relocation w/ 300amp fuse & master disconnect switch mounted within reach of external track safety personal
Internal fuse panel~completely rewired chasey
Gizzmo MS Electric Boost controller
RCE 650cc injectors
Walbro 190in tank / 255in line
Aeromotive fuel pressure regulator
CoolingMist Vericool Water/alcohol Injection system
NGK Spark plug wires
MSD high vibration coil/box
SDS EM4E fuel/ignition system
J&S~Safeguard w/ flat shift & launch control & knock a/f pillar gauge
PLX M300 wideband o2
innovative digital fuel pressure gauge with recal
Odessy digital fuel level gauge
Autometer~EGT / digtl water temp / digtl oil prsr / vac.bst / amp meter
aluminum heat shielding on hood and needed wires/hoses
PAR 3rd gear ~ case brace
Quaife LSD
SPEC flywheel and stage 4+ clutch
King6Fab custom tubular lower xmember with integrated traction bracing
Stainless clutch line
short shifter w/ TWM knob & blk leather boot
aluminum covers~coolant/washer fluid/brake/power steering
aluminum radiator cover
C/F hood to radiator plate
Trackmate GPS datalogging system / also used for true speed readings on the streets
LED turn signals & reverse light mounted rear in license plate frame
twin HID projector lights in solid state headlight housings
6" driving lights in bumper with dark tint Luminex covers
6" front bumper to brakes cooling ducting
KSport 8-piston 13" floating front brakes
KSport hydraulic hand brake
new rear brake hard lines
SS soft brake lines on each corner
Summit aluminum brake booster vacuum canister
MSP rear brakes w/ EBC yellow pads
Kosei K1TS rims / Dunlop Start Specs and Wintersport 3Ds)
Sparco roadline pedals (brake turned towards gas for heel toe)
Tein SS coilovers
Megan front upper Strut bar
Welded in rear srtut cross bar 1"x2"
Welded in unibody bracing 1"x2"
GT-Spec ~ trailing arms ~ v-brace
Megan Racing rear lateral arms
King6Fab Sway bar lateral arm mounts
Addco rear sway bar
Autopower race roll cage w/ mounted quick release fire extinguisher
one off front and rear diffusers w/ 3 chasey mounts each
one off c/f hood with "chris's toy" stenciled on the underside
1 of 15 c/f hatches & 1 of 15 c/f headlight covers
one of a kind oem c/f rear spoiler
Shark fin 12v antenna
TenzoR steering wheel
Sparco quick release system
Horn relocated
steering column mounted water injection / accuvolt warning leds
modified center console area~houses aux power switches and fuel quick tune knob
black interior conversion
TenzoR rally seats
TeamTec custom JetPilot 8~point drivers harness
RCI 5~point passengers harness
memory foam blk ultrasuade back area (rear seats removed)
sony head unit
focal front speakers
infinity kappa rear speakers
jlAudio W3V3 8" sub box & R/F~amp
Aerogear Evo f/b ~ Milleneam r/b ~ shogun sides
Front fenders built up to fit bumpers, rear bumper w/ center panel,&side skirts molded in
LED Side Markers
EDIT: there are many more mods to list, and they come to mind after my initial posting. Still my list's already 3 pages down, so it's best to leave it as is. While also stating,"I have many more mods I can list from this car."
Accomplishments:
I've had this car for going on 14 years now. I kept chasing my dream with it, even though I am now in a wheelchair. It's been many things to me in the past, but we will continue on till the end together. It still drives on 28psi of fun boost, and I am as happy to see others take her out as I was to drive her my self in the past.
Trent188
Trent
2002 Mazda 323 Astina SP20
Mod List:
Brakes & Suspension
Front - Super Stiff No brand Lowered 55 mm
Rear - Lovells Lows Lowered 45 mm
Interior
Tuning Expert Alloy Gear Knob With Blue LED's
Tuning Alloy Pedals
2x 9 White SMD LED's In Roof Interior Light Sides With a 12 SMD White LED In Centre
Central Dash Backlight Changed to Blue Single SMD LED's
White 5 SMD LEDs Put In Glove Box
White Festoon 2 SMD LED Put In Boot Light
Instrument Cluster Back Light Changed To SMD LED BLue
Carbon Fiber Cluster Surround
Carbon Fiber JBS Customs Shift Boot
Exterior
13 SMD LED Parker Globes
Phillips Crystal Vision H1 High Beam
6000K HID Low Beam
Phillips Crystal Vision H3 Fog Lights
T10 Precision 5 SMD LED Number Plate Lights
Blue Valve Caps
X Force Mini Cannon with Silencer
Removed Black Side Trims And All Sp20 Stickers
Smokey Side Indicators
Blue Mazda Speed Oil Cap
Painted Matt Black Extractors Heat Shield
Animal Noise Loudspeaker
Black Altezza Headlights With SMD LED Reverse Lights And Indicators
Center Of Bonnet Sprayed Black
18" Mazda 6 MPS Wheels Powder Coated Black With Nankang 215/35/R18 Tires
Sprayed Front Grill Badge Black
Pod Filter In Carbon Fiber Cylinder Heat Sheild
Yoshi Doll On Tow Point
LED Headlight Indicators
Carbon Fiber Streetline Stubbly Antenna
Audio
JVC KD-G845 Head Unit
Focal 6.5" 165A3 Splits In Front Doors With Custom Wooden Bracket
Focal 6" 165CA1 Speakers In Rear Doors
Kenwood 640 Watt 4 Channel Amp KAC8401
Kenwood 12" Subwoofer In Kenwood Box KFC-W3010
Fusion EN-AM4502 2 Channel Amp Bridged
Lawrence C
Lawrence Castillo
2001 NB8C
Mazdaspeed headlights.
Mazdaspeed spoiler.
Mazdaspeed rear diffuser.
Advanz clear corners.
H&R Coilovers.
XXR 521 16x8 +20.
Yokohama Paradas Spec 2 205/40.
Cquence drilled and dimpled rotors.
Carbon fiber wrapped center caps.
55w 5000k High intensity discharge head lamps.
35w 3000k Fog lights.
K&N Polished short ram intake.
Valve cover painted wrinkled black.
Heat-shield painted wrinkled black.
Racing beat power pulse exhaust.
Exhaust works race pipe.
MTX 10" Subwoofer.
MTX Blue thunder amplifier.
Pioneer DEH-P3900MP.
Kicker 6502 component speakers.
Dynamat Extreme.
Voo-doo shift knob.
